DOUBLE FLUSHING TOILET
Old 10-21-00, 10:04 AM
Guest
Post
WE HAVE A NEW HOUSE THAT IS LESS THAN ONE YEAR OLD. WHEN EITHER TOILET IS FLUSHED AND WHILE THE TANK IS FILLING THE WATER IN THE BOWL WILL GO DOWN AGAIN LIKE ITS BEEN FLUSHED AGAIN. WE CHANGED THE FLAPPER AS TOLD BY THE PLUMMING DEPT AT HOME DEPOT BUT THIS HAS NOT CORRECTED THE PROBLEM. NEED HELP SINCE WATER IS WASTED. THANKS, MIKE
Old 10-21-00, 08:21 PM
Guest
Post
You have a water saver toilet, you need to lower the full level in the tank, or install a water saver tank flapper.
Best Regards Plumber2000
www.atozplumbing.com
Old 10-22-00, 09:53 AM
Guest
Cool
Try a flapper with a float around the chain.
HTML code is On
