pumping domestic waste
Old 09-17-04, 07:05 AM
vermontdoc
Question pumping domestic waste
I am thinking of putting in a new bathroom, problem is that it would be really tricky and obrtrusive to have the waste lines run in a 'normal' manner so I'm thinking that there must be a way to pump the 'stuff' from a low point in the bathroom and out and into my existing waste lines by running pipe overhead in the basement. I looked under google and couldn't find the right name for this system. Any help on the name and your experiences with that would be appreciated.
Old 09-17-04, 07:26 AM
Mike Swearingen's Avatar
www.saniflo.com
Good luck!
Mike
Old 09-17-04, 07:29 AM
vermontdoc
meaning.........?
Old 09-17-04, 07:50 AM
Meaning that the Saniflo systems are made-to-order for what you want to do.
Just click on www.saniflo.com to see.
You also need to contact your Building Inspection Department for local code, permit and inspection requirements, and plan your system from there, using the Saniflo or Saniflo-type equipment for the basement bathroom.
Good Luck!
Mike
Old 09-17-04, 08:52 AM
vermontdoc
thanks, Mike, that's exactly the kind of information I was looking for. gotta go check your site. :-)
HTML code is On
