Please help with the steps to connect my Tub/Shower Drain/Waste Vent in my basement that I am remodiling. It has the rough-in for the DWV, but the other side of the wall is already finished. I have a fiberglass tub/shower How can I make the final connections to the drain when I cannot reach in from the back? The side is also blocked from 2x6 framing. I have a PVC Drain/Overflow kit.
Also at the hardware store they said I did not need a p-trap becuase this was not a sewer. I need one correct?
Thanks, Bill.Read More
The copper pipes in my home have recently started whining. It happens for about 5 minutes each time and will stop if I run a bath or other high volume faucet. I've heard of this as a regulator or main valve problem. Any suggestions?
AFG Roawell GARead More
