help removing sink drain flange
What is the trick to removing the sink drain flange? Trying to replace new rim-mount sink but can't get the flange off of the old one. Special tool?
Try using a screwdriver and tapping (with a hammer) on the nubs to get it to turn. If that fails, get a drill and put a few holes into the retaining nut, then break it, again, with the screwdriver and hanmmer. If you still haven't had any luck, use a cold chisel and a bigger hammer.
