clean-out with pressure
Old 11-20-00, 12:01 PM
Guest
Post
I've seen a device in a Home Depot that attaches to your garden hose. After it is inserted into a drain pipe you turn on the hose and the water pressure inflates a collar which seals off the pipe and uses the pressure to clear the obstruction. Has anyone used these and what did you think of it??
Old 11-20-00, 04:22 PM
Guest
Post
A Drain King. They do OK, usually. They can be a lifesaver if you have to clear a drain that has a lot of tight-turn fittings in it, or one that doesn't have a cleanout close enough to the clog for a snake to reach it.
