toilet make loud whining noise when filling
Old 11-23-00, 11:50 AM
Guest
Post
Please help, After I replace the inside parts to our toilet it makes a loud whinning noise when it is filling. It can be heard throughout the house. Any help would be great.
Old 11-23-00, 01:53 PM
Guest
Post
Are you sure the shut off valve is open completely? The problem is a restriction someplace in the water line. A kinked or partially blocked supply line could be the problem, or it could be a restriction at the base of the fill valve.
Old 11-24-00, 09:57 AM
Guest
Post
Brother,
Check you head-space at the Cloggins valve.
The smilee could be caught at the pyloric valve. Or better yet, check to see if you head is up your forth point-of-contact.
Just checking the site as you suggested, saw your post and couldn't resist.
CYA
