Old Cardboard Pipe Crushed by Tree & Type of replacement pipe
Old Cardboard Pipe Crushed by Tree.
I have a home built in 1964 which I thought was really not that old. However the sewer line back then was made of oiled cardboard. I am digging the line up myself and am going to run PVC pipe from the house to near the sidewalk past the crushed pipe. What do I need to do to connect the old pipe to the PVC? Also the line makes a 45 degree angle down the line. Will I need to do anything special to make this or can I cut the pipe and put a connecting head on there? Thank you for the help!
OILED CARDBOARD????? Never heard or seen it. I will have to watch this post closely to learn something new. I started my apprenticeship in 1970 and never ran across this type of drain pipe.
Received 1 Upvote
1 Post
Never seen or heard of "oiled cardboard" sewer line either, but you should be able to connect PVC pipe to it with Fernco couplings or no-hub couplings.
Fernco couplings are neoprene rubber sleeves with large stainless steel clamps. No-hub (aka Mission) couplings are neoprene rubber-lined stainless steel sleeves with torqued ss clamps. Either should be to code there.
Good luck!
Mike
Good luck!
Mike
Measure the outside diameter of the "cardboard pipe" to make sure what size coupling you buy. Compare with PVC fitting to make sure it will work. PLEASE post back with the results. Pictures would be great....gotta see this pipe.
I will have to take a picture of this. I have section of pipe I just took out that is solid roots through the pipe. I was playing around with the pipe a little bit it seems to be firm and can hold me standing on it, but if I stomp it it crushes, I can cut it with a butter knive.
I sounds to me like he is referring to "Orangeburg Pipe". A commonly used product back then. More info here:
http://www.sewerhistory.org/articles...orangeburg.htm
Received 1 Upvote
1 Post
Rainbird nailed it.
I've heard of, but have never seen, "Orangeburg" pipe.
Replace ALL of that stuff. The ONLY solution to galvanized supply pipes and Orangeburg drain pipes is total replacement.
Good Luck!
Mike
Good Luck!
Mike
What Should I use to Replace Sewer Line?
I got all that orangeburg pipe dug up to where it connects to the street and is metal again. Is the PVC pipe they sell at home depot ok to use as a replacement? Also the line takes a 30 degree or so angle then another angle at the metal. Do I need to measure the angle and get a specific piece, or can you make adjustments to fit the angle on the spot? Thanks for all help guys! I can not afford to pay someone do to this so I have to do it myself. Any help is great.
Of course you do. Anytime you put fittings in pipe in PVC, you have to securely bond those fittings together.
Where you buy the pipe and fittings will have the glue, read the sticker on the numerous cans and determine which one suits your piping that you are using.
Anytime you are going from dissimilar materials, use the method of fernco rubber couplings that are code approved, saddles when installing into main sewers approved by the city, and the like.
Backfill with sand, not dirt around new piping.....or you will submit new piping to undo pressure which will cause sloping problems.
Received 1 Upvote
1 Post
Just info :First we had the vitrified sewer pipe and you put cement in the hubs or also called the bells. Then for a time they went to a rubber like ring on the male end.Just slip them in the bells.I have seen vitrified pipe that is over 100 years old. When you wash it up its just like the day it was made.Then they went to the orangeburg pipe .Rolled up felt
with a tar like in it.You just tapped them together in a coupling is all. Then thanks to PVC we have it made, We hope
ED
ED
