joining 1" copper to 1" cpvc. Is there a way without sweating a copper fitting?
I will be joining 1" nominal copper to 1" cpvc and I am wondering what my options are. Of these listed below, what is best? (i would prefer to avoid sweating anything actually... but if i must....)
1) sweat a union onto the copper. then glue the cpvc into the union
2) sweat a male fitting onto the copper then join to a cpvc femaleadapter
3) sweat a female fitting onto the copper then join to a cpvc male adapter
4) a union that would compress onto copper side but glue on the cpvc side?
any other suggestions?
Go with number 3. Hoping this is not in a wall though. Most states do not allow threaded joints to be in walls. Female CPVC adapters are not really recommended either. Good luck.
With dragon #3 sounds good But if you dont want to solder . A 1" compression to Mpt 1 " coupling there and a mpt on the CPVC. I would not try a compression fitting on the CPVC.
Just in case... I will have 1" cpvc pipe literally connecting to copper so I don't need any more fittings on the cpvc side...
