pressure check
Old 12-28-04, 09:18 PM
rob
rob is offline
pressure check
Hi - I've read posts about pressure testing lines and making sure that ends are capped and (I thought) not connected to any valves.
My question:
What would be the configuration to pump up the line with a compressor without putting a valve between the compressor hose and the line under test? Seems like the compressor on it's own might have some small leaks.
Thanks
Old 12-28-04, 11:48 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi Rob
- you may have misunerstood this procedure. You have to have a valve fitted on the line, or else how could you pressurise it ? This is frequently done in the well biz, and I built a Tee with gauge and fill valve on 2 of the ends. The third is left to make adaptable for whatever I'm using it on.
Old 12-29-04, 10:17 AM
rob
rob is offline
Hi nomind - Maybe I'm making it too complicated! Here's a quick picture with the pipe being tested. There is a cap on one end. There is a tee on the other end with a guage and a valve to shut off once the line is pressurized. Is this what you had in mind?
Thanks
Old 12-29-04, 10:53 AM
majakdragon's Avatar
Rob, Your link did not show up in the thread. Only the name of a server or something.
Old 12-30-04, 09:45 AM
rob
rob is offline
Hi - Maybe I'll just put the link in directly. Here is my crude picture!
http://us.f1.yahoofs.com/bc/ea876c10...uXE1BBj3bbABqb
Old 12-30-04, 09:53 AM
Still no picture. Just the Tripod link logo. Not sure why not.
Old 12-30-04, 10:14 AM
Maybe this will help and I think it is what you have.
X is the valve...then a tee with gauge...rest of pipe with a cap.
This should be what you need.
Hmmm, my O (gauge got moved off the tee when I submitted this.
X--T--------------------------]
O
Old 12-30-04, 04:33 PM
rob
rob is offline
ok, thanks, that's (picture) the easy way! That's exactly what I have, and the compressed air comes in at the valve.
Old 12-30-04, 11:56 PM
nomind's Avatar
Hi guys,
I think we're all talking about the same thing in slightly different configurations. Top flat of the F is a gauge, bottom is the airvalve. Small leg is adaptable by reducers etc. to fit any pipe size.
gauge
F----------------------pipe being tested
air valve
HTML code is On
