simple question re trap cleaning
Old 12-30-04, 12:53 PM
When I clean traps under sinks, do I need any kind of plumber's tape or sealant to keep the connection from leaking once I put it back together (it's white plastic pipe)?
Thanks.
Old 12-30-04, 01:04 PM
majakdragon's Avatar
Normally if they are PVC you do not need any type dope and they are usually hand tight. As long as the gaskets/nylon washers are in good shape. The metal traps also do not normally need dope as most use a rubber gasket and do not normally leak. Metal however usually needs a wrench or channellocks to firmly seat. Good luck.
HTML code is On
