Can I replace the dishwasher with a washer and dryer combo?
Old 01-06-05, 05:54 PM
Bsan1221
I am going to purchase and apartment that has in the kitchen a dishwasher. I dont really care for the dishwasher and was thinking to get a washer and dryer.
Does the washer and dryer combo (all in one) use the same type of pipe system, and drainage as one of these all in ones?
Old 01-06-05, 06:18 PM
majakdragon's Avatar
One thing you would have to do is run a cold water line over to the washer. Dishwashers are hooked up to hot water only. Next is the drainline. Most washers are required to have a 2" discharge drain with a trap and vent. Dishwashers are discharged into the sink drain and are much smaller lines. You would have to check on this. I also do not know what electric requirements are for a combo unit. Venting the dryer would also be necessary.
Watch this post for someone who may be more familiar with those units. I have only given you what I know about them. Good luck.
Old 01-06-05, 06:31 PM
Bsan1221
Thanks for your response.
I was just curious.
I was looking into the LG Washer and Dryer Combo. The current Dishwasher is a Maytag.
I can tell you the electrical conductor:
Below Ground Copper 220 Volts
Panel Type: Circuit Breakers, Panel Capacity: 125 AMP
I dont know if this helps
Old 01-06-05, 08:20 PM
Plumber2000's Avatar
You still need what majakdragon said regardless of what you have.
HTML code is On
