leaky compression fittings
Old 01-08-05, 04:09 PM
New Member
What is the correct way to tighten a compression fitting? I've had varied results trying to connect copper tubing; sometimes they leak and sometimes they don't. I'm installing a new undercounter filter and I'd like the job to work the first time out of the gate. I never know if I'm over or undertightening the joints.
Thanks
Old 01-08-05, 07:22 PM
Plumber2000's Avatar
Apply a little bit of pipe dope at the point the compression ring wedges between the stop and pipe, this works every time, tighten up real good.
Old 01-08-05, 10:26 PM
As Ron indicated, the brass ferrule ring seals a compression fitting, not the threads.
Hold the fitting with a back-up wrench and tighten it as tight as you can.
Good Luck!
Mike
Old 01-09-05, 04:40 AM
New Member
Leaky compression fittings
Good Luck!
Mike
Mike,
Thanks for the help on the compression fittings.
Bob
New Member
Thanks for the help.
Bob
HTML code is On
