Bolt broke on sump pump lid
Old 01-13-05, 09:39 AM
I put a new pump in my sump basin (looks like a black garbage can set in the concrete floor). When I was tightening one of 4 bolts to hold the top down, the bolt snapped off. Any thoughts on what to -- drill a new hole, etc.? I would imagine it's important to get the lid on properly to keep sewer gasses in.
Old 01-13-05, 09:46 AM
majakdragon's Avatar
You would probably want to have 4 bolts for the reason you stated. Would it be possible (not knowing the diameter of the bolt or how much is sticking up) to take the end of a chisel and tap along the outer edge of the bolt in a countercolckwise direction to get it to unscrew? Between the turning motion and the vibration it may just come out. Otherwise I guess you are stuck with drilling a new hole. Good luck.
Old 01-13-05, 03:14 PM
The bolt broke off inside the hole. Guess I'll drill a new hole and go from there...
HTML code is On
