shut off
shut off
Hello
I had a plumber take all the polybuylene out of my house and now one of the faucets in the upstairs bath runs only a small amount of cold water. I just moved in so don't know if it was like that before. Before I call him back, do you think the shut off he installed is faulty? I can change it myself if it needs it or perhaps clean out something init but wanted anopinion before I get under the sink as my old back is cautious these days.
Thnax
Pete
Thnax
Pete
Since it is only one fixture, I would say that the valve is bad or plugged. If you feel like it, you could disconnect the tubing at the valve and hold a rag over the opening and turn it on and off 2 or 3 times to clear it. This would also let you know if the valve itself is bad. Good luck.
