Loud clicking noise in pipes
Hello:
I live in a newly built house (1 year old) with an oil furnace and hot water baseboard heat. Whenever the heat comes on (which when it is 5 degrees out like today is quite frequently) I can hear a very distinct, and sometimes loud, clicking noise in the pipes. This noise lasts for about 15 seconds and then stops. I do not know much at all about plumbing. It sometimes sounds like someone is dropping a marble or something in the pipes. What is this and is there a way to fix it? Thanks
It could be the electronic ignition on your furnace or it could be the heating duct work expanding slighly as it heats up. Mine do both when I first turn on the heat in the AM.
Sounds like expansion noise. When the heat is called for the hotter water going through the pipes causes them to expand. Could also be one of the pipes rubbing a stud when expanding.
If it is the pipes expanding, not much you can do. If the pipe is rubbing a stud, you MAY be able to find out where and cut a little bigger opening for it to move through. Neither is going to be easy. Sorry.
