washing machine....will not fill up with water
Old 01-22-05, 12:34 PM
Having a problem with no water filling the washing machine. The pipes are not frozen. Getting water to the kitchen...the washing machine is on the same floor in a room behind the kitchen. The fuse is ok. The cycles of the machine work...just getting no water? Any one???
Old 01-22-05, 12:45 PM
majakdragon's Avatar
Try turning off the valves where the hoses attach and disconnect hoses from the washer. Turn the water on while holding the hose in a bucket or washer. If you have water from the hoses then it appears the fill valve is done for. You will have to replace it. While you have the hoses off, check the screens for blockages. Good luck.
HTML code is On
