faucet noise
Old 02-01-05, 07:25 PM
faucet noise
My American Standard single lever kitchen faucet probbably about 20 years old makes a howling noise when turned on.It changes pitch as handle is moved up or down.
I can feel a vibration in the housing.I have removed the aireator but it still sings.
Do you think parts are still around for it at a store like Home Depot or should I just replace it?
What do you think it could be?No leaks found and it still works just lots of noise.
Thanks for all the help.
Old 02-02-05, 03:21 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Sounds like a gasket or "O" ring that needs replacing. You can check about replacement parts, some still have them as they didn't change design a whole lot. Broken gaskets, washers and "O" rings are like holding a reed between your thumbs and blowing. Very annoying sound. Good luck.
Old 02-02-05, 06:47 AM
will do
Yes that is exactly how it sounds.I will tear into it this weekend.Thanks a million.
