What is the tiny pipe from laundry faucet
Old 02-28-05, 07:44 PM
asmic
I found a tiny pipe from my laundry room faucet while planning to replace the sink. It comes from the faucet and drains beside the main drain pipe. What is it? And what should I do with it when replacing the sink?
http://www.networknt.com/IMG_2107.JPG
http://www.networknt.com/IMG_2108.JPG
Thanks in advance.
Old 03-01-05, 04:22 AM
majakdragon's Avatar
Is it going into a floor drain? You said "Drains beside the main drain". If so, it is a type of automatic trap fill. Every time you run water, there is a small flow into the floor drain to maintain a seal to keep sewer gases from coming into the house. Many people forget about unused floor drains and then have an odor problem when the trap drys out and gases start entering. Thats all I can think of. Good luck.
Old 03-02-05, 05:53 AM
asmic
Thanks Majakdragon
I think you are right. I will remove the faucet and check it out this Friday.
HTML code is On
