Adding plumbing for a second bathroom sink
Old 03-02-05, 08:41 AM
I have one sink in the bathroom that can fit a double sink vanity. I'd like to run the pipe for the drainage and water lines over to the left to put in another sink. The current drainage pipe is coming is from the far right wall. Can I connect the other sink to the drain going across from a sink on the left side? I feel confident connecting the water supply but not about connecting the drain. Thanks for any help.
Old 03-02-05, 08:46 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
I am not sure how far apart the basins will be but you may be able to use a combination waste (like under a double kitchen sink) to solve your problem. This would also eliminate any vent problems that could occur. Good luck.
