banging pipes
Old 03-04-05, 04:50 PM
pickster
banging pipes
I was wondering how you cure pipes that bang when you turn the water on and the pipes make noises when not being used. I put a air chamber on the main line coming into the house right before the water heater. It bangs more when I turn the hot water on across the house in the kitchen. The hot water heater is a forced air exhaust and is only six months old and it makes noises also when it's not even heating up. Thanks
Old 03-04-05, 08:37 PM
You either have a loose washer in a valve that was recently turned on or off, or you have a high water pressure problem that needs to be dealt with.
Have your pressure checked with a gauge with all faucets off in the home........make sure you bleed off the water briefly to make sure that you do not gauge thermal expansion created by the water heater.
HTML code is On
