Leak under sink
Old 03-07-05, 04:04 AM
pipper
Leak under sink
I'm not sure if this is something I can do myself or if I need to call someone. Both the hot and cold water lines are leaking where the shut off valves are. I don't think they are screwed into place .. looks like it may be clamped, but I don't know for sure. Can anyone tell me what this type of joint would be called and if it's something I can do myself? Thanks for any help.
Old 03-07-05, 05:31 AM
majakdragon's Avatar
pipper, Welcome th the DIY Forums.
Not sure what the name of that connection is but it IS crimped and would need to rent or buy a tool to fix it. I would get someone to fix it and possibly replace this type connector with something you can repair yourself in the future. Good luck.
Old 03-07-05, 05:42 AM
pipper
thanks .. that's what I thought. I just shut off the main line and pulled the entire thing. I'm heading out to the hardware store to find a replacement that's easier to fix.
HTML code is On
