strange noises
Old 03-07-05, 06:37 AM
scooter61
strange noises
There is this noise that occurs after I flush my toilet and while taking a shower in my master bathroom. It is hard to explain but it sort of the same sound as a toilet makes when the tank refills, but it is very brief. This noise happen after the tank has refilled and it also happens when taking a shower and when you finish taking a shower. It seems to only happen in the upstairs. Any advice?
Old 03-07-05, 06:56 AM
majakdragon's Avatar
scooter61, Welcome to the DIY Forums.
Try turning off the supply valve under the toilet and then use the shower. Sometimes the fill valve on the toilet will suck air after a flush or when other fixtures are used. Worth a try. Good luck and reply back with results or other questions.
HTML code is On
