Shower spouting water when diverter is off
I replaced the shower faucet thinking the reason why the water would still come from the shower head was due to a faulting diverter in the old faucet. After replacing I am still seeing water come from the showerhead. When I turn on the shower there is quite a bit of water pressure coming from it. I have also replaced the sink faucets as they were spraying water everywhere. Is this a potential sign of too much water pressure in the house. I am no plumber just looking for somewhere to start.
Hi chaddy23,
Welcome to the DIY Forums.
You can purchase an inexpensive water pressure gage at your local home center or hardware store.This will tell you exactly what your water pressure is. It screws on to an outside faucet It read within the 40 to 60 range. This is a normal reading. If it is much higher than this you will need a pressure reducing valve installed where your water lines enter the house.
If this is a new problem, you can call your local water dept and ask if work has been done recently that could raise your water pressure. You can also talk to your neighbors and ask if they have been experiencing the same problems
If you find that you need to install a PRV, reply back and we will help you to Do It Yourself.
Good luck with your project.
You may be able to call your local water dept and ask for a pressure check. If they will not do that, ask if any new subdivisions have been built near you . This is always a reason for departments to raise the pressure. Good luck.
