Soldering copper very close to black iron gas line
Old 04-21-05, 01:07 PM
vegassatellite
I have to solder a 3/4 copper water line but it is very close to an active gas line composed of black iron pipe. This joint is within 1/2 inch of the blackpipe. Will the black iron pipe be fine if I solder that close to it?
I guess my question basically comes down to whether or not the black iron gas pipe is tolerant of <2500 degrees of nearby heat for a short duration?
Old 04-21-05, 06:46 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Unless the gasline is leaking, you should have no problem with soldering next to it. Have to ask, what type torch are you using? 2500 degrees is a bit steep for solder. If in doubt, put a piece of sheet metal between the two lines. Good luck.
