Outdoor faucet
Outdoor faucet
If when you turn on the water, it comes out the handle, but doesnt drip otherwise. Need to replace whole thing, or just washer. Thanks in advance.
Received 1 Upvote
1 Post
Turn the water to it off and take it apart. sounds like the washer is bad can also have to tighten the top packing nut some also. If the water runs ok and some comes out the stem. With the water running can you tighten the nut there on the stem some ? if its that kind
ED
ED
I did try tightening it, no effect. the water does run out the faucet also, just some comes out the handle when turned on. Thanks for the quick response.
