Water Heater
Water Heater
I am installing a tankless water heater and have run into a problem. There is no shutoff valve for the gas line leading to the waterheater. I feel confident that I can replace the water heater if I can figure out how to shut off the gas. Will I have to shut off the gas for the entire house to replace the WH? Any help would be appreciated.
Thanks,
Mark
Thanks,
Mark
Received 1 Upvote
1 Post
Dont know where you are put code should call for a A valve by the W/H there . I guess you have to turn the gas off at the meter now to work on the lines. Are you sure you can work on the gas lines there? Id check first.
ED
ED
