How do I fix the outside sillcock
Water doesn't flow from the outside valve. It's a frost proof automatic draining wall hydrant. Can that be repaired or does it have to be replaced?
Received 1 Upvote
1 Post
Can you get to it inside???? screwed in or solder. if you have to put a new one in??? Is water turned on to it for sure??? Then shut the water off to it open the valve some and unscrew the stem cap pull it out see what you have try and turn the water back on to it inside see what you get.
ED
ED
