pvc waterline leak
Old 05-11-05, 08:54 AM
B
pvc waterline leak
I have 1/2inch black pvc waterline coming into house form outside
the pipe comes out of the cement floor and it started leaking about 2 inches from the bottom
I cut the pipe and i am trying to couple it together
I am not sure what i should be using to join it together
Should i be using an insert and clamps or some kind of compression fitting
I am curently without water and any advice would be appreciated
My other alternative is to replace the pvc with copper lines which means diggin up the yard and disassembling a deck that is in the way
Any1 with any insight to this problem HELP
tks in advance
Old 05-11-05, 09:06 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
bellababy, Welcome to the DIY Forums.
Most PVC is made to be glued. Check the pipe and see if there is printing on it. You may have ABS and not PVC. Using glue and a coupling will give you piece of mind. Compression fittings can and do come off. Good luck.
Old 05-11-05, 09:53 AM
Ed Imeduc's Avatar
Wink
When all I know is you have a 1/2"black plastic pipe. Most of them go together with that
I think you got it. might want to put 2 clamps on each side
ED
