Burying (Hiding) a rough In drain in basement
Old 05-14-05, 08:23 PM
RoosterMan
Hello All,
I just started finishing my basement. I want to make my full roughed in basement bathroom a half bath. The only problem is the rough in for the tub drain is smack in the middle of where I need to put my hallway. I am in Virginia, and essentially what I want to do is cut the line flush to the floor, chisel away enough concrete to be able to glue a cap on it, patch the concrete and lay dricor (1" subfloor) over top of it.
Does this sound like its ok to do?
Old 05-14-05, 10:43 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
I see no reason you cannot do what you plan. It will have no effect on any other plumbing. Good luck with your project.
