Split Water Pipe
Old 05-16-05, 06:18 AM
putt4317
Split Water Pipe
My pipe leading to my outside water spicket has split open in my basement. Do I have to replace the pipe or can I get some type coupler to go over the split and seal it up?
Old 05-16-05, 08:32 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
putt4317, Welcome to the DIY Forums.
Is it just a pipe, or is it actually a frost-free hosebib that has frozen and split? The frost-free type are 10" long or more and the washer that actually shuts the water off is on the end inside the house. You will have to replace the whole faucet assembly if it is this type. If it is just a pipe, you will have to put in a new piece of pipe. Where the pipe split will be thinner metal and will probably leak no matter how you try to patch it. Good luck.
