Copper Pipe Bender
Old 06-02-05, 08:07 AM
T
Copper Pipe Bender
Hi,
I bought a copper pipe bender - the spring type. I used the correct one for my half inch pipe and tried to bend it but the pipe snapped. Thinking I was being too heavy handed I tried again with the same consequence.
Any ideas what Im doing wrong?
Thanks
Old 06-02-05, 08:16 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Yes that spring only works on soft copper. The copper in a coil. Buy elbows for the hard copper.
ED
Old 06-02-05, 08:22 AM
T
I tried to use elbows but the elbow has a leak and its about 14" down under the floorboards (coming from the basement). Its also right beside a plastic waste pipe so awkward to apply heat.
Is there any other option to bend the pipe?
Thanks for replying so quickly.
Old 06-02-05, 09:35 AM
majakdragon's Avatar
You can buy the same size copper in soft (coil). That way you can go back to an open joint, solder there, and run the soft copper the rest of the way. Good luck.
Old 06-02-05, 09:42 AM
T
Is soft copper strong enough to hold the pressure to a washing machine/sink etc?
Do they sell it in one of the big stores? Im also thinking perhaps I should have just used the plastic piping...in hindsight.
Old 06-02-05, 09:48 AM
Soft copper has all the pressure requirements you should ever need. Just make sure when you buy it, that you get the same OD copper. They also sell refrigeration copper in a roll that is a different size OD. (Outside diameter). Home centers carry it in assorted length coils depending on how much you need.
