hot water drain
hot water drain
Can I drain my hot water tank into my sump pump and expect the pump to get rid of the water and sediment or does the water go thru this immersible pump and block it up? I have two sinks in the celler but they are higher than the water tank so would that be a problem?
I was going to drain the tank after turning the power off with a hot and cold water faucet open along with the water tank supply then let it run till it was clear. OK?
