Noisy pipes at water heater
Old 07-17-05, 07:08 PM
Penny4urthought
Hello,
I'm a novice in plumping so any help is appreciated. There a two pipes extending out from the top of my gas water heater, and both make clicking noises when any faucet in the house is turned on. I was told it was air in the pipes, I installed a shock absorber by the cloth washer, but this did not solve the problem. The noise is loud enough that I can hear it through the walls in the adjoining room. Thanks in advance.
AZ
Old 07-20-05, 09:02 PM
Check your water pressure......along with checking to see if the cold water inlet valve has a loose washer.
Old 07-21-05, 12:49 PM
B
Received 13 Upvotes on 9 Posts
I have never seen one but someone mentioned a while back some water heaters have a 'check ball' in the nipple to stop hot water from traveling up the pipe. When you run the water the little ball bounces around in there making a clicking noise.
Could be it, maybe not.
Baldwin
