loss of water pressure
Old 07-18-05, 11:17 AM
loss water pressure throughout the house after my electric service was upgraded and a new gound installed. house built in 1969 with copper pipes. could the new ground be the problem?? if you flush a toilet, all water to the shower (2nd floor) cuts off. any suggestions????
Old 07-18-05, 06:46 PM
notuboo's Avatar
You're problem is not related to electricity or the electric bonding.
Sounds like either low pressure (clogged screen of pressure reducing valve if installed or bad diaphram on same valve) OR a partially closed valve. Could be the main line valve or the branch that goes to the second floor.
Check the valves first, then check the pressure with a cheap gauge.
Old 07-19-05, 05:41 AM
Water Pressure Regulator
can i check the screen myself or do i need a plumber. believe screen is on the left bottom of regulator. right?? regulator is bell shaped right before meter?? have pretty hard water in rockland county ny.
Old 07-20-05, 08:09 AM
found the problem. the valve on a unused water softner was not set to bypass. someone must of accidentally pushed it recently. thanks for your help.
