Leak under Kit. sink drain
Found everything under my kit. sink soaked. Found there was a leak right under the bowl like part right under the drain. I do I repair-seal or stop the leak? THank you so much for any help.
Could be as simple as a compression joint that has come loose to a replacement of putty to the basket strainer.
Please be more specific of where the leak is.....pictures will help. Corrosion usually leads you to the problem.
