stumped
Old 08-17-05, 11:18 PM
fruityboy
stumped
need help please the other day my bathroom hot water tap stopped flowing so i changed the washer it worked for a couple of goes then nothing again so i replaced the faucet with a new one same again every other tap in the bathroom works fine any ideas would be much appreciated
thank you in advance
Old 08-19-05, 12:09 AM
steve_gro's Avatar
Received 1 Upvote on 1 Post
There may be something lodged in the angle stop (presumably you used it when you replaced the washer). Try turning off the angle stop & disconnecting the supply from the faucet, point the riser into a bucket, open the stop & see what you get. If there's debris in the stop, turn off the water & unscrew the handle & stem. You can then have a cohort briefly turn the water on & off to flush any obstruction.
