Garbage Disposer Backing Up In Double Sink
Old 08-29-05, 06:21 PM
BIGJIM05
For Some Reason My Disposer Is Spitting Water And Smell Back Into My Double Sink When I Am Using The Disposer. What Can Be Causing This To Push Water Up The Left Hand Sink When The Disposer Is Running On The Right Hand Sink?
Old 08-29-05, 07:04 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
I would say that you have a partial clog in the drainline. Double sinks usually mean a combination drainline. Two sinks hooked into one drain with a crossover pipe. The disposer is pushing the water harder than the faucet water does so it backs up into the other sink. May want to run a snake down the drainline. Good luck.
Old 09-03-05, 09:36 PM
noisaw
Your drain is clogged. It will probably require a snake to clear it. It usualy clogs in the wall.
