Fluidmaster 400
Old 09-03-05, 10:50 AM
B
Received 13 Upvotes on 9 Posts
Fluidmaster 400
Is there an adjustment on these so they don't shut off quite so fast, can't find the paper that came with it?
It shuts off with a 'boom' and the pipes shake. I'm on city water and the pressure doesn't seem excessive.
Thanks,
Baldwin
Old 09-03-05, 11:02 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
If it is not a pressure problem I don't see anything pertaining to your problem in my instruction manual. (just bought an American Standard toilet and they come with the Fluidmaster valve). I am including their website that has more solutions to problems. Good luck.
www.fluidmaster.com
Old 09-03-05, 11:16 AM
B
Never thought of looking there. Here's what it says:
Prof. Flush:
If you have a sudden banging of your water pipes or toilet valve when it shuts off, you have what we call "Water Hammer. If you are not using a Fluidmaster fill valve then this is a perfect oppurtunity to purchase at Home Depot the Whisper Fill Valve by Fluidmaster. This fill valve has a specially designed regulator that will reduce the noise as well as stop the "BANG" of your pipes.
I'll have to find me one of these.
Thanks
Old 09-03-05, 11:34 AM
B
Old 09-03-05, 08:44 PM
5
The Fluidmaster 400 is not particulary prone to hammer; it does taper the flow somewhat before shut off. It is quite possible that you have a high pressure problem, which no valve can overcome.
Old 09-03-05, 08:53 PM
Your answer lies in this link
BANGING PIPES < READ #4
Old 09-03-05, 09:13 PM
noisaw
Thanks,
Baldwin
If you have water hammer you need a slow closing ball ****. Those are the ones with the arm and float ball. I like Wolverine Brass. You will pay more but it's worth it.
Old 09-03-05, 09:57 PM
B
OK, I went and watched the float. It rises slowly with the water level about half way, stops for maybe 3 seconds then snaps to the closed position. Is this normal or maybe something is binding inside the valve for a couple seconds?
I installed this about a year ago and I sure the banging wasn't there then. We do have a lot of white chunks in our water.
I'm gonna check the pressure, out of curiosity, then buy a new valve and see what happens.
Thanks guys,
Baldwin
Old 09-03-05, 11:22 PM
steve_gro's Avatar
Whoa, white chunks in the water (esp the hot)?
Google the following:
"water heater" AND diptube
