Copper vs Steel pipes
Old 09-08-05, 02:32 PM
D
I'm just wondering what are the differences/issues between using copper and steel supply pipes for water. I need to remodel a shower and am wondering why I would use either. I have an older house with both. Is the main difference that copper wont rust inside?
Thanks for the Info!
Dennis
Old 09-08-05, 02:49 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Main reason(s) are that it won't rust and will not flake off in a few years, clogging your fixtures. If you remodel with copper and have to tie into a galvanized steel line, you must install a di-electric union. If you don't you will have a condition called electrolosis that will eat away at the pipes in the area they are joined at. This is caused by joining dissimilar metals. It is a chemical reaction.
If you use steel pipe, you will have to put up with rusty water whenever you turn on the shower. Good luck.
