6 inch clay pipes
Old 09-24-05, 06:49 PM
BIGJIM05
6 inch clay pipes
What would be the best thing to use to replace a 6" clay pipe that is broken in my basement floor?
If I use clay is there anything special I would have to use to connect the new to the old? Any special sealer needed? And how expensive might this be?
Thanks
Old 09-24-05, 07:43 PM
Use a 6" to 6" Clay to PVC Rubber Fernco @ each end. You will need a short section of 6" PVC pipe to make the repair.
You cannot reduce the piping inbetween as this would cause a reduction inline which is not to code.
Make sure you torque the clamps to 60 foot pounds of torque when tightening.
Old 09-24-05, 07:47 PM
BIGJIM05
Is it a rubber piece that has a clamp on each end or am I thinking of something different? I saw a rubber piece same diameter but just with 2 clamps and I dont see how I can torque this?
Thanks again
Old 09-24-05, 08:30 PM
BIGJIM05
oakum or rope to seal pipes in ground?
I have been told that I should use oakum or rope to seal the pipes in the ground. Have you ever heard of this and should the seal be completely around the pipes when joined?
Old 09-24-05, 09:28 PM
Fernco
This is an image of a fernco rubber coupling.
Old 09-25-05, 05:57 PM
BIGJIM05
thanks
Just wanted to say thanks
With your help the problem seems to be solved.
