cleanout cap damaged
Old 09-27-05, 01:10 PM
elliottmaire
My husband accidentally ran the lawnmower over the cleanout cap outside. We have tried to replace it, but the part that you put the wrench on is completely missing. Any ideas how to remove the cap and replace it?
Old 09-27-05, 01:38 PM
wrmiii's Avatar
What's it made of?
Would you mind posting back with the type of material this plug is made from. Plastic- Brass ??? It will help us help you. Thanks.
Old 09-27-05, 01:56 PM
T
Received 2 Upvotes on 2 Posts
If it's plastic, you can drill two holes large enough and far enough apart to get the handles of a pair of pliers through. Insert the pliars and use leverage to twist out the plug.
