Vent question
Old 10-23-05, 07:43 PM
Carrie
Vent question
Hello:
I am by no means a plumber so am looking for some advice.
I've lived in my current home about 1.5 years, today I noticed a sewer gas smell in an upstairs bathroom. Upon further investigation it seemed to be coming from the bathroom exhaust fan. If I turned the fan on the smell went away, but came back as soon as the fan was off.
Ascending to the attic, it appears that the 2 bathroom fans upstairs share a common vent through the roof with the waste stack.
That seems like a problem to me but what do I know. Is that a problem? If so what't the easiest way to fix it? It probably involves a new stack through the roof for just the bathroom fans huh?
Thanks!
Old 10-23-05, 11:01 PM
steve_gro's Avatar
Received 1 Upvote on 1 Post
I wish you would post a picture of this; if I'm reading it correctly it's a very bizarre setup. If indeed the two bathroom fans are tied into a plumbing vent stack, it's a terrible job and should be fixed. I'm not sure if you can tie the fans together or not; a call to the fan mfg would answer that, but they should NOT be venting into the plumbing.
