Acrylic Shower pan installation on top of tile??
Help???
Im in the process of installing a new shower pan (and shower). The new pan in 36.5 inches square where the old one was 36" square. The new pan will not fit into the 36" cavity unless I chip out the existing to tile to the new 36.5 dimension. Instead can I add a new subfloor (appox 1 inch) to raise the floor level to the tile and then install the pan on top of the tile (and level sub-floor)?? I had to relocate the drain, so the new drain plumbing can be adjusted to fit. What kind of drain do you recommend?? Id like to use a drain where the flange is on the bottom of the pan and a threaded colllar is screwed into the flange from top. Seems to me this style would be easier to install.
Most Sincerely,
Paul Bamberg
Most Sincerely,
Paul Bamberg
If you can, take pictures and link them from www.photobucket.com so we can better understand your situation; I follow you until you mention installing ontop of tile when you say you are raising the floor 1". I would use a no-caulk all brass shower drain. This will allow you to work on this drain down the road perhaps there be an issue with it.
Better explaination
Thank you for the quick response!!! Ill try to take some pics tonight!! The original shower pan sat directly on the sub-floor. The cement backer board and the tile were laid around the shower pan. When I removed the original shower pan, there is now a cavity that is 36 by 36 inches where the shower pan was. This cavity is about 1 inch deep. The new shower pan is a 1/2 inch larger and will not fit in the cavity where the old pan was. My options are add 1 inch of additional sub-floor so that the floor under the shower pan is the same height as the tile floor. Then I would install the shower pan over this new level floor. Or; I would have to enlarge the existing shower pan cavity by chipping out an extra 1/2 inch clearance around the existing tile. If I chipped out the tile to enlarge the cavity, then the new shower pan would fit and I would retain the way it was orginally installed. Which way should I install the new shower pan?????
Help??????
Most Sincerely
Paul Bamberg
Help??????
Most Sincerely
Paul Bamberg
