Is their a way to control a water pump remotley?
Old 11-02-05, 08:06 PM
stinkypoo75
Hi,
I was just wondering if anyone had any ideas on how to control a water pump remotley. Basically, i work for a theatre, and we desire the effect of water streaming down a window. The water will trickle down the window, into a trough and be pumped up to above the window where holes in hose deliver this trickling effect. However the pump needs to be turned on off stage about 20 ft away. Any suggestions or ideas would be great.
Thanks!
Old 11-03-05, 07:52 AM
T
Just use a switch on the stage and run a "temporary" electrical line to the pump.
Old 11-03-05, 11:16 AM
L
A water timer or electric timer might be used, too.
