When shortening copper supply pipes...
Old 11-17-05, 09:41 AM
F
Thumbs up When shortening copper supply pipes...
...under the kitchen sink is it OK to re-use the existing piping and elbows or will I have a problem with residual solder etc...on them ?
I only have a limited time to remove,shorten and re-install as I am in a first floor condo and must shut-off the water to to whole building in order to do the job.(not sure if this even meets the code in Alameda County,CA..but that's another story I guess).
Or would it be safer to have all new fittings and pipe on hand you think?
Thanks again for any help
Old 11-17-05, 10:04 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
You can reuse pipe and fittings but it would be easier to get new and have everything ready before you shut off the water to a whole building. The old fittings and pipe would have to be wiped to get them to fit together again and if you have a small clump of solder remaining (especially inside the cup of a fitting) it will not seat properly. This would waste time. Good luck.
Old 11-17-05, 10:46 AM
F
Thanks..again..for the advice,dragon.
