Mysterious pipe poking into bathroom
Old 12-02-05, 06:30 AM
Hobiedog
I've got an upstairs bath that I'm ready to floor with ceramic. If you sit on the potty and stretch your leg out, you'll put your foot on a ~4" round screwed-on floor plate which is a cover for a vertical flush-mounted pipe. This bath is the highest in the house, so I'm wondering if it's a vent. The house was built in 1950. I"d like to start putting down the wonderboard, but I'm 'wondering' if I should cap it off or cutout the wonderboard and tile and keep it intact. It sure looks crummy and I'd like to be rid of it; I’m afraid my small kids will discover it and drop ‘fun things’ down the pipe, but the last time I removed something that I didn't comprehend, it was the deadend hot and cold 'shock absorbers' ( ~12" of closed-end pipe at the highest point ) to prevent water hammer and I'm still wacking myself in the head for that one.
thanks
Old 12-02-05, 07:25 AM
majakdragon's Avatar
Hobiedog, Welcome to the DIY Forums.
That cover "sounds" like a coverplate for a cleanout. You often see them in stores and public places. Sometimes on the floor and sometimes on a wall. I have to ask about this cap and pipe. If you remove the cover, is the pipe open or does it have a cap that seals the opening of the pipe? I have not seen a clean-out where the brass cover seals the pipe. Usually there is a cap or brass plug IN the opening (threaded). Let us know. Good luck.
Old 12-02-05, 12:31 PM
Hobiedog
Mysterious pipe
When the screw-cap is removed, you can see into the pipe; there is no other plug. I now see some internet references to a 'barrel trap', which this seems to be.
Old 12-02-05, 10:54 PM
steve_gro's Avatar
If it's a drum trap, you would be able to see an inlet & outlet, and if it's in active use, you could run water in the tub & watch it pass through.
If you have a digital camera, you could post a picture (worth a thousand words) at http://www.photobucket.com.
HTML code is On
