Wall Sinks
Old 12-03-05, 08:00 PM
C
Wall Sinks
Simple question: Is a behind-the-wall wood cross brace from stud to stud always required for pedestal and wall sink attachments, or is there any other alternative?
Old 12-04-05, 05:29 PM
The only alternative to not using a wood support would be toggle bolts, and those do not hold at all since they use the back of drywall for the support. Most times they will snug in tight initially, then slowly loosen up from use of the sink. Do it right and install the support to prevent loose water line and drain connections to the sink over time.
Old 12-05-05, 09:46 AM
shacko's Avatar
sink support
Dunbar is right, do the right thing now, or do it over, sorry.
