Tying into existing drain
Old 12-06-05, 02:26 PM
GWilliamson
How can I add a second toilet without going into slab. Can I raise the existing toilet and tie into the drain someway ? The new bathroom will be next to the old one. Any ideas would be appreciated. they say $100 and up to tunnel under slab.
Old 12-06-05, 05:52 PM
notuboo's Avatar
Look at toilets with macerator pumping systems like Saniflo. You might find this to be an option for the slab work.
Good luck with your project...
Old 12-09-05, 01:12 PM
LAZYTNCAJUN40
raise it
you can raise up using 2x6 then run your pipe thru the wall but first locate ur sewer line outside it should be within a foot of the surface it is easy to jack hammer a hole out and dig down and under the footing homes there are built with a 1ft deep footer you can try one of these its not hard
