basement sprinkler install
Old 12-10-05, 05:16 PM
hdiy's Avatar
I'm thinking of installing one sprinkler head above my oil boiler in the basement.
There are plenty of cold water supply lines to T, for a supply to the sprinkler.
Is there anything more complicated to installing a sprinkler head, than running and soldering the copper 1/2" pipe?
Thanks.
Old 12-10-05, 06:42 PM
I would check with your local authority of buildings and construction on this one; a dedicated check valve is needed to separate this line since it would be considered a dead end if you branch this line off of a main line of any distance over a few inches. Sounds overkill but dead ends in potable water systems can cause health issues.
They may give the go ahead to not use the check valve. If it was a 10 foot line, a check valve would be a must have.
Old 12-10-05, 07:17 PM
hdiy's Avatar
Thank you.
HTML code is On
