uh-oh -- water leaking from under driveway
Old 12-12-05, 01:07 PM
T
trout
from my washing machine. could this be a mainline break? what should i do here?
thanks!
trout
Old 12-12-05, 05:25 PM
Doug Aleshire's Avatar
trout,
From washing machine, doubt it.
From broken main water line (between street and house) quite possible and if so, this is usually the owners responsibility. If this is running water, you could turn water off within home and see if it stops. If not, then you need the water turned off at the street.
Unsure where you live, type of home, on slab, basement, crawl, so the best answer, call the City first - do it now - they should have people on the ready for this inquiry!
Good Luck!
HTML code is On
